EK Launches Crosshair V Formula-Z Waterblock
For those looking to watercool their latest FX-8350 setup, EK has you covered with a new Crosshair V Formula-Z MOSFET/990FX combination waterblock. If you are a Crosshair watercooler, be sure to drop us some pics in our modding forum because we love to see them!
"EK Water Blocks, premium water cooling gear provider, will soon release new Full-Board (FB) water block for ASUS flagship AMD AM3+ socket Crosshair V Formula-Z motherboard.The upcoming EK-FB ASUS C5F-Z for ASUS Crosshair V Formula-Z motherboard will be a single piece Full-Board water block which will directly cool AMD 990FX northbridge and the power regulation (VRM / MOSFETs) module. Due to the budget nature of this water block the AMD SB950 southbridge will remain cooled using ASUS factory provided heatsink . This water cooling solution will require two G1/4 threaded fittings and will sport a high flow design therefore posing a minimal flow restriction to the water cooling circuit.Furthermore this new water block will be compatible with the original version of ASUS Crosshair V Formula motherboard and will as such replace the existing EK-FB ASUS Crosshair V lineup.Expected release date is 10th of December with MSRP around 70€ incl. VAT."
[gallery include="" size="medium" link="file" template="file-gallery" columns="2"]
Popular Posts
How to upgrade the SSD and reinstall Windows on your ROG Ally or Ally X
See the mammoth ROG Dominus build that takes Intel's 28-core Xeon W-3175X to the Extreme
The ROG Dominus Extreme pushes the boundaries of PC performance in our awesome CES 2019 build.
Breaking world records with the ROG Maximus XI Gene and the Intel Core i9-9900K
Tasked with pushing performance on the Z390 platform as far as possible, we invited the best overclockers to ROG HQ for a week of extreme overclocking.
How to overclock your system using AI Overclocking
AI Overclocking one-click tuning makes its debut on Z390 motherboards and we have a quick how-to guide to get you started.
HW GURUS win the ROG OC Showdown Team Edition 2
The results are in from our second ROG OC Showdown Team Edition. See who posted the top scores.
Breaking records with the Maximus X Apex and i7-8700K
ROG is obsessed with chasing the highest overclocks and fastest performance, and Coffee Lake is our new muse on the Maximus X Apex.
The Rampage VI Apex claims more performance victories with Intel's new Core i9-7940X and i9-7980XE
After dominating extreme overclocking with the first wave of Skylake-X CPUs, we've taken the latest 14- and 18-core models to sub-zero extremes.
