Xonar U7 USB Sound With Headphone Amp
ASUS has just launched its Xonar U7 USB sound device with headphone amplifier. While not ROG branded, the U7 has very clear audio at 114dB SNR, partly thanks to its Hyper Grounding PCB design (that was originally introduced on the Xonar Phoebus) and a 32 ohm-150 ohm headphone amplifier built in to pump up the sounds to your (Vulcan or Orion) headset.
It features the same technology capacity as modern internal soundcards with 7.1 surround sound audio and 192KHz/24-bit HD audio and the latest Dolby Home Theater v4 that can upmix all audio to 5.1 or 7.1 output and use Dolby’s expertise in sound control over Windows' own.
The U7 has dedicated microphone and volume controls, which means even if you’re using a PC or notebook for gaming they are close at hand and quick to use rather than fiddling with software settings. Being USB powered means that it’s easily disconnected and used for a multitude of hardware: use it with your PC while at home, and then throw it in your bag with your notebook when you head out. Its built in S/PDIF out means you can also easily hook it up to a home theater amplifier as well.
If you're after a new USB sound device and would like to know more, give us a shout in the forums!
Popular Posts
Where to catch ROG at Gamescom 2025
ROG is doing more than just revealing wild new PC gear at Gamescom 2025 — it’s amping up the party. Check out what we're up to.
The new ROG Dev Accelerator program gives your indie game dev studio the boost it needs
Our new ROG Dev Accelerator program provides a select number of promising indie devs with the hardware they need to build their games.
The ROG Astral GeForce RTX 5090 OC smashes 6 new overclocking records
The ROG Astral GeForce RTX 5090 OC takes what you love about ROG graphics cards and ups the ante to provide you more power than ever before. But don’t take our word for it — look at the records it’s smashing.
The ROG Virtual Assistant gets an AI upgrade with new features
OMNI is getting a big upgrade. Our ROG Virtual Assistant now packs AI-powered features designed to boost your productivity and user experience.
Get ahead of the game with the latest ROG gaming tech from Gamescom 2024
From new X870 motherboards to OLED displays and plenty of mice and keyboards, here’s everything ROG announced at Gamescom 2024.
Buy a GPU and get a free Steam code for Like a Dragon: Infinite Wealth
Purchase select GPUs from ASUS, ROG, or TUF Gaming and dive into an epic adventure with a free Steam code for Like a Dragon: Infinite Wealth!
