Cooling Solutions for Gaming Phones: A Deep Dive into ROG’s Thermal Mastery
In mobile gaming, performance is fundamental. But without efficient cooling, even the most powerful hardware can fall victim to thermal throttling. The ROG Phone 9 and ROG Phone 9 Pro tackles this challenge head-on with a suite of cooling technologies that go beyond internal hardware tweaks. From a smart layout of components to advanced accessories like the AeroActive Cooler X and AeroActive Cooler X Pro and the ROG Chill Case, ROG has engineered a multi-layered defense against heat.
Three Layers of Cooling for Every Scenario
Picture this: You're 30 minutes into an intense ranked match, your fingers are flying, your phone is working overtime, and just as you're about to secure victory. You start to feel the heat — figuratively and literally. Your hands suddenly feel like they have been set alight, the frame rates start dropping, and performance dips at the worst moment. This is exactly the problem ROG is trying to solve with the ROG Phone 9's thermal cooling system.
Instead of relying on a one-size-fits-all solution, ROG has come up with a three-layered cooling strategy that adapts to how you're using the device:
First, there's GameCool 9, the phone's built-in thermal engine, which manages heat internally during everyday gaming and multitasking. Then, when you're pushing the limits in graphics-heavy titles, the AeroActive Cooler X or X Pro can be clipped on to deliver a burst of active cooling right where it's needed. And for daily drivers who want passive, silent cooling without bulky accessories, the ROG Chill Case provides temperature control that literally fits into your pocket.
| Cooling Solution | Type | Best For | Key Features |
| GameCool 9 | Built-in | Everyday gaming and long play sessions | Centered SoC, vapor chamber, graphite sheet, boron nitride conductor |
| AeroActive Cooler X | Clip-on External | High-performance gaming, short & long term | Thermoelectric cooling, fan + heatsink, customizable RGB, extra trigger buttons |
| AeroActive Cooler X Pro | Clip-on External | Extended sessions, multimedia & pro users | Larger fan, subwoofer, USB-C power boost, 29% better cooling |
| ROG Chill Case | Passive Accessory | Daily use, casual gaming, multitasking | Composite vapor chamber, reduces temp by up to 17%, improves audio direction |
Each layer works independently or together depending on the demands of your session, giving you a flexible approach to managing thermal performance without compromise.
GameCool 9: Our built-in cooling system
At the heart of the ROG Phone 9’s thermal performance is GameCool 9, a carefully designed internal setup that handles heat dissipation based on how long and how intensely you are gaming. Unlike other cooling systems that rely solely on software throttling, GameCool 9 uses a multilayered hardware approach to manage thermal buildup across all gaming scenarios, whether it is a 10-minute quick match or an hour long open-world exploration.
The SoC (system-on-a-chip) is placed right in the center, nestled between two battery cells. This layout cleverly ensures that the processor (the phone's hottest component) is kept away from areas where your hands generally rest, allowing for a more comfortable grip during extended gaming sessions. The heat rapidly transfers outward using a boron nitride thermal conductor, a material which is claimed to have 200x greater conductivity than air.
A larger graphite sheet (57% bigger than the previous generations) helps spread the heat across a wider area, improving cooling efficiency during gaming sessions by up to 12%. For long gaming marathons, the new and improved vapor chamber distributes heat uniformly throughout the device. The result? Consistently smooth performance with no frame drops, even in the most demanding titles.
Want to understand the advanced tech behind it (like thermoelectric cooling and the Peltier effect)? Check out this in-depth forum post.
AeroActive Cooler X & X Pro: High-performance external cooling
When internal cooling isn’t enough, especially while running AAA titles or while conducting boss-level raids, the AeroActive Cooler X Pro steps in. This clip-on accessory uses thermoelectric cooling technology powered by the principles of the Peltier Effect, creating a cold surface that pulls heat away from the back of the phone.
The AeroActive Cooler X doesn’t just blow air; it creates a powerful temperature gradient that actively cools the device well below ambient conditions. Paired with a high-performance fan and a built-in heatsink, this system can drop surface temperature by 12°C compared to using the phone alone.
Users can control cooling levels manually or let the system auto-adjust via the Armoury Crate app, ensuring the right balance between power and performance. The AeroActive Cooler X Pro takes things further with a 12.5% larger fan, 29% better cooling efficiency, and a built-in subwoofer for immersive 2.1-channel sound; all while being powered directly through the phone — no external cable required.
The AeroActive Cooler isn’t just for show; it maintains stable performance in games like Zenless Zone Zero and Wuthering Waves, keeping frame rates at a locked 60 FPS even after an hour of continuous play.
The ROG Chill Case: Passive cooling with ideal protection
Not everyone wants to attach a fan every time they boot up a game, and that’s where the ROG Chill Case comes into play. Designed to provide protection with passive cooling, this case features an integrated composite vapor chamber that evenly redistributes heat from hot zones to cooler outer edges.
The result is a reduction in back surface temperatures of up to 17%, which translates directly into a cooler feel in the hand and more consistent performance during casual gaming, streaming, or multitasking.
The Chill Case enhances the user experience in subtle but impactful ways. A channel near the bottom speaker redirects sound toward the front, simulating a dual front-facing speaker setup for more immersive audio during landscape use. And because it’s built using non-metallic materials, it doesn't interfere with wireless signals, ensuring smooth 5G and Wi-Fi performance.
The results: Smart cooling anywhere you go
The ROG Phone's multi-layered cooling approach is designed not just to prevent overheating, but to actively enhance the gaming experience. With heat managed more effectively, the Snapdragon 8 Gen 3 stays at higher clock speeds longer. Surfaces stay cooler to the touch, and gameplay remains smooth without dips in performance. You can play longer without discomfort, and over time, lower sustained temperatures help reduce wear and tear on the phone's internal components.
In our testing, the results speak for themselves:
| Game | Device | Average Temperature | Average FPS |
| Zenless Zone Zero | ROG Phone 9 | 43.4° C | 60 FPS |
| ROG Phone 9 + AeroActive Cooler X Pro | 31.3° C | 60 FPS | |
| Wuthering Waves | ROG Phone 9 | 42.2° C | 59.1 FPS |
| ROG Phone 9 + AeroActive Cooler X Pro | 31.2° C | 59.1 FPS |
Whether you're a casual gamer or a competitive grinder, the ROG Phone 9’s smart cooling ecosystem gives you the confidence to push your phone to the limit and keep it there.
Popular Post
Settings guide: How to set up your gaming monitor
ROG Ally vs ROG Ally X: All the improvements in the new ROG handheld
How to extend the battery life of your ROG Ally or ROG Xbox Ally
Yes, OLED gaming monitors can work great in sunny rooms. Here’s what to look for
ROG's monitor game is leveling up with Tandem WOLED tech, a new display coating, and next-gen dual-mode glory.
Our new ROG monitors pack the brightness and display coating combo that you need to fight sunlight and play during the day.
Discover how ROG revolutionizes mobile gaming with advanced cooling solutions like the GameCool 9 system and AeroActive Cooler X Pro, featuring cutting-edge thermoelectric technology powered by the Peltier effect.
The ROG Strix Ace XG248QSG gaming monitor puts the pedal to the metal with a 610Hz refresh rate
Generations of ROG displays have fueled esports gamers’ need for speed. Meet our latest tournament-grade monitor.
Get inky blacks in any environment, deft reflection handling, vibrant OLED colors, and great gaming specs in a 32-inch monitor.
How the Neo Proximity Sensor on the latest ROG OLED monitors improves on its predecessors
The latest ROG OLED monitors feature a new upgrade: the Neo Proximity Sensor. Here's what it offers over previous models.
