VGA Hotwire On The Maximus V Extreme, DirectCU II & MATRIX HD 7970
The OC trio of VGA Hotwire, OC Key and Subzero sense, which were first included on the Rampage IV Extreme, are also additions to the new Maximus V Extreme. Focusing on VGA Hotwire specifically, these two boards can sync up with VGA Hotwire-enabled, high-end ASUS graphics cards, including the current GeForce GTX 680 DirectCU II and Radeon HD 7970 DirectCU II.
VGA Hotwire plugged into the Maximus V Extreme
VGA Hotwire soldered into the HD 7970 DirectCU II
The two DirectCU II graphics cards have specific PCB spots to solder on the wires, or in the case of the upcoming ROG MATRIX HD 7970, simply plug in. The other ends then go into the corresponding pins of the Extreme motherboard. This allows the OC Key to read the voltages and apply changes directly to the card, in real-time, without using software.
Close Up:
GeForce GTX 680 DirectCU II PCB - there are three measurements: GPU voltage (GPU OVG), memory voltage (MEM OVL) and PLL voltage (PLL OVL). Two wires are needed for each one and female plugs are needed at the other end for the Extreme PCB pins. There are two sets of pins on the Extreme PCB for up to two cards. The Radeon HD 7970 DirectCU II has the six along its top instead:
Popular Posts
See the mammoth ROG Dominus build that takes Intel's 28-core Xeon W-3175X to the Extreme
The ROG Dominus Extreme pushes the boundaries of PC performance in our awesome CES 2019 build.
Breaking world records with the ROG Maximus XI Gene and the Intel Core i9-9900K
Tasked with pushing performance on the Z390 platform as far as possible, we invited the best overclockers to ROG HQ for a week of extreme overclocking.
How to overclock your system using AI Overclocking
AI Overclocking one-click tuning makes its debut on Z390 motherboards and we have a quick how-to guide to get you started.
HW GURUS win the ROG OC Showdown Team Edition 2
The results are in from our second ROG OC Showdown Team Edition. See who posted the top scores.
Breaking records with the Maximus X Apex and i7-8700K
ROG is obsessed with chasing the highest overclocks and fastest performance, and Coffee Lake is our new muse on the Maximus X Apex.
The Rampage VI Apex claims more performance victories with Intel's new Core i9-7940X and i9-7980XE
After dominating extreme overclocking with the first wave of Skylake-X CPUs, we've taken the latest 14- and 18-core models to sub-zero extremes.
