ASUS Announces EA-AC87 - AC1800 4x4 MIMO GigE to Wireless Bridge
Announced at CES 2015 earlier in Jan, the EA-AC87 is now be available to buy, allowing you to bridge a wired GigE connection to WiFi at AC1800 wireless speeds from its four antenna (4x4 MIMO). It's perfect for small form factor systems that can't squeeze in a WiFi PCIE card, and it's the next step up in performance and range over USB options, and the CAT5 cable can be extended further to allow placement almost anywhere.
It's dual-mode includes:
- Media Bridge (wireless client) mode it adds Wi-Fi to any wired network device
- Access Point mode upgrades any existing router or network to 5GHz speeds.
It's ASUS exclusive AiRadar has universal beamforming that measures and focuses the direction of the signal to maximize performance and coverage reliability, reaching up to 465m2 (around 5,000ft2).
[gallery include="" size="large" link="file" template="file-gallery" columns="2"]
Popular Posts
Where to catch ROG at Gamescom 2025
ROG is doing more than just revealing wild new PC gear at Gamescom 2025 — it’s amping up the party. Check out what we're up to.
The new ROG Dev Accelerator program gives your indie game dev studio the boost it needs
Our new ROG Dev Accelerator program provides a select number of promising indie devs with the hardware they need to build their games.
The ROG Astral GeForce RTX 5090 OC smashes 6 new overclocking records
The ROG Astral GeForce RTX 5090 OC takes what you love about ROG graphics cards and ups the ante to provide you more power than ever before. But don’t take our word for it — look at the records it’s smashing.
The ROG Virtual Assistant gets an AI upgrade with new features
OMNI is getting a big upgrade. Our ROG Virtual Assistant now packs AI-powered features designed to boost your productivity and user experience.
Get ahead of the game with the latest ROG gaming tech from Gamescom 2024
From new X870 motherboards to OLED displays and plenty of mice and keyboards, here’s everything ROG announced at Gamescom 2024.
Buy a GPU and get a free Steam code for Like a Dragon: Infinite Wealth
Purchase select GPUs from ASUS, ROG, or TUF Gaming and dive into an epic adventure with a free Steam code for Like a Dragon: Infinite Wealth!
