Project: Phenomenon By Hanshen Oe
Based around a heavily modified NZXT Switch 810 tower case, Hanshen Oe's Prokect Phenomenon was created with a simple philosophy: I've been a pc enthusiast for just about a year and a half. Building a gaming rig for just a "so-so" experience was my only goal at that time. I started with an average build, using a single, average graphics, however as time goes by the addiction turned nasty! I've begun demanding more and more from my rig. Combining an SLI setup with some of the best components I could grab was the only option, as I took to running games/software at the highest setting possible yet didn't want issues or lag. Other than pushing the components to the limit, water cooling was the next inevitable thing. It led me to modding the case so that it can hold more water cooling components, yet still keeping it very good looking. The result of this is was the "Phenomenon".
Project Phenomenon Spec List
- Core i7-3770K (overclocked)
- Maximus V Formula motherboard
- 2x ASUS GeForce GTX 670 DirectCU II (SLI)
- 4x DIMM G.Skill Ripjaws-Z memory (red)
- Xonar Phobeus sound card
- EK Watercooling
[gallery include="" size="medium" link="file" template="file-gallery" columns="2"] The top of the NZXT Switch 810 case was modified to accept a triple 120mm fan EK radiator, painted in white, and installed in the roof. This included a custom designed, laser cut acrylic grills, as well as new separation panels, also fabricated from acrylic. Phenomenon includes a custom made pedestal to house a second, quad 120mm radiator of the water cooling loop, again painted white. Both the compartments contain subtle use of LED's to illuminate the parts, and to draw attention to the water cooling blocks. [gallery include="" size="medium" link="file" template="file-gallery" columns="2"] The system features a fully watercooled ROG Maximus V Formula motherboard, with an overclocked Intel Core-i7 3770K processor. The two ASUS GTX 670 DirectCU II graphics cards have had their coolers removed and replaced by EK waterblocks, and are sitting in SLI, while at the bottom of the motherboard sits a ROG Xonar Phoebus providing the high end gaming audio to go with the impressive graphics power. Phenomenon features fully color-coded individually sleeved cables, and also holds two reservoirs, so the liquid level in the system can be viewed from both the front and side of the case. [gallery include="" size="medium" link="file" template="file-gallery" columns="2"] What do you think of Hanshen's Phenomenon? Let us know in the forums. [simpleviewer gallery_id="61"]
Popular Posts
Behind the scenes with PC modder Derek Wilson, builder of our epic new OMNI PC
Bringing OMNI to life as a 4-foot tall gaming PC was no small task—but Derek was up to the challenge.
An inside look at Ben Q’s brass-filled Blanco build
Ben Q's brass-filled Blanco build fuses a custom case and cooling hardware with ROG components for a one-of-a-kind PC.
Behind The Bunker: A Look At Snef's Combat-ready Black Ops 4 Build
Take a tour of a battle-ready PC created by renowned modder Snef and inspired by Call of Duty: Black Ops 4.
Around the world in 100 quadrillion clock cycles
The ROG Strix GL502VS has spent the last year looking for the best gaming experiences in the world and has seen everything from VR in Prague to parkour in Bulgaria.
Celebrating the globetrotting ROG Strix GL502VS with Mexico’s makerspace movement
We take an inside look at Mexico's quickly growing makerspace movement, including 3D printing ROG case mods and designing our very own custom GL502VS cover.
All Aura Sync everything: Inside Snef's Aurora Borealis-inspired build
How far can you take an obsession with RGB? Snef goes full Aurora Borelis with Aura Sync.
